BobFord
Mar 23, 2018Aspirant
ReadyNAS 628X Problems.
I started to encounter problems at the beginning of the week when advised that I had a degraded scenario. The problem was that in the main HD display I could not identify the 'yellow' drive (maybe bi...
Mar 27, 2018Guru - Experienced User
BobFord wrote:
There's 6 x 10TB & 2 x 12TB
With RAID-6, you can only use 10 TB of the two 12 TB drives - you need four of the largest size to use all the space. The volume size should be 60 TB (54.5 TiB) - not 47 TB.
So something is still wrong with the volume, hopefully mdgm-ntgr can help you figure it out when he gets the logs. It could be simply that it isn't done resyncing.
BobFord
Mar 28, 2018Aspirant
I rebooted the NAS as it was not visible on the Raidar app. I downloaded the logs to a zip and emailed them but the email bounced claiming another address was not found
Any thoughts?
Thanks
