OZrevhead
Nov 04, 2015Aspirant
ReadyNAS Duo has stopped working
Hi, I have a ReadyNAS Duo RND2000 v2 with 2 1TB drives, I tried to access it today and its not on my network map anymore. It was silent with network activity lights flashing and no lights on the front...
JennC
Nov 05, 2015NETGEAR Employee Retired
Hello OZrevhead,
If you can browse files using one of the computers on the network then that means the files, disk and NAS are fine. It is a different problem on the computer that cannot browse. Maybe the way you access it, permission settings or SMB protocol of the computer.
How do you try to access the files on the computer that cannot browse the files? What file protocol do you use? What IP address do you use to browse the files?
OZrevhead
Nov 05, 2015Aspirant
I can only browse the files with disk 1 out, with disk 1 in it wont boot, hence my questions:
What are the username and password defaults?
If I install another 2TB drive in disk 1 will the NAS repair itself?
Thanks
