OZrevhead
Nov 04, 2015Aspirant
ReadyNAS Duo has stopped working
Hi, I have a ReadyNAS Duo RND2000 v2 with 2 1TB drives, I tried to access it today and its not on my network map anymore. It was silent with network activity lights flashing and no lights on the front...
JennC
Nov 06, 2015NETGEAR Employee Retired
Hello OZrevhead,
If you are able to browse without the disk 1 inserted and just have disk 2, this means disk 1 is too faulty that it also affects the OS of the NAS.
Please check the disk 1 with diagnostic tools. Inserting a replacement disk to bay 1 where you removed disk 1 is needed if you want to be protected. I believe your NAS is currently using XRAID, this RAID level allows you to have 1 fault disk and still keep the data instace since disk 2 mirrored disk 1. Please make sure to never change disk order, disk 2 should always be in its respective bay.
OZrevhead
Nov 12, 2015Aspirant
I fitted a brand new 2TB drive to disk 1 and let is rebuild, next day I checked the status and it says the new drive is "dead", this sounds more like the NAS is faulty right?
I can still access disk 2 and read my saved files.
- JennCNov 12, 2015NETGEAR Employee Retired
Hello OZrevhead,
Please make sure the new disk is listed at the HCL.
You may also try to test the disk with diagnostic tools to make sure.
If the disk passed the test then it may be time for you to get a newer version of ReadyNAS chassis. While you can still access files, I strongly suggest to back up the data.
- OZrevheadNov 14, 2015Aspirant
Hi, my new Seagate drives are on the HCL, I fitted another new one to disk 2 and the NAS has again reported it as "dead". I fitted the original 2TB WD drive into my pc and am testing it now with the diagnostic tool but SMART status says its OK.
I have copied everything back off the NAS so no risk now.
Report back soon
- OZrevheadNov 15, 2015Aspirant
OK the original 2TB WD drive that stopped the NAS from booting has passed the WD test tool quick test and extended test. Testing the first "dead" seagate now, it has passed the quick test and SMART status is PASS.
- StephenBNov 15, 2015Guru - Experienced User
What model seagate drive?
ST2000DM001
The NAS detects it fine but says its dead.
- StephenBNov 16, 2015Guru - Experienced User
OZrevhead wrote:
ST2000DM001
A lot of folks have had trouble with DM drives in a NAS (not just ReadyNAS either). I suggest WDC Red or Seagate VN drives, which have a lot less problem posts.
You can try powering down the NAS (then remove drive and the power cord for a bit). Then power back up, and try reinserting the drive.
