OZrevhead
Nov 04, 2015Aspirant
ReadyNAS Duo has stopped working
Hi, I have a ReadyNAS Duo RND2000 v2 with 2 1TB drives, I tried to access it today and its not on my network map anymore. It was silent with network activity lights flashing and no lights on the front...
Nov 15, 2015Guru - Experienced User
What model seagate drive?
OZrevhead
Nov 15, 2015Aspirant
ST2000DM001
The NAS detects it fine but says its dead.
- StephenBNov 16, 2015Guru - Experienced User
OZrevhead wrote:
ST2000DM001
A lot of folks have had trouble with DM drives in a NAS (not just ReadyNAS either). I suggest WDC Red or Seagate VN drives, which have a lot less problem posts.
You can try powering down the NAS (then remove drive and the power cord for a bit). Then power back up, and try reinserting the drive.
