Gordon-H
Mar 29, 2017Aspirant
Readynas Duo v2 Getting either bad discs or corrupt root
I had this Duo v2 working with 2 WD 3tb drives on the compatibility list. They were getting close to full so I got 2 WD 4tb discs to trade out the 3tb discs. I started by removing disc 2 and replaci...
JennC
Mar 30, 2017NETGEAR Employee Retired
Hello Gordon-H,
After performing the factory default, if you still experience either error message - Corrupt root, ERR Used Disks, Could not mount Root RAID – there is still a problem with the chassis, hard disks, or the Operating system on the ReadyNAS. I guess it is best you check the disks to isolate the problem. You may use diagnostic tools that the brand name/manufacturer of the disks can offer to check the disks. I saw a discussion where they shared diagnostic tools they use.
FramerV
Apr 03, 2017NETGEAR Employee Retired
Hi Gordon-H,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
