aaccee
Apr 29, 2012Aspirant
Readynas duo v2, new member
Hi, new member with a few questions. I have installed 2 x 2tb new compatible drives and have raidar up and running. Q: On the Raidar panel it shows 5.3.4 under the i heading but 4.3.4 when you click ...
aaccee
May 02, 2012Aspirant
Update, I have removed hdd 2 and completed a factory reset on hdd 1 but the volume indicator is still blank. The indicator light shows the presence of hdd 1 (there were 2 lights before I removed hdd 1). The log shows the status of hdd 1 as ok as it did for both before,and is still showing that the volume scan failed to run and the share path could not be found. The status light on the far left is on (& was before).
When you referred to 'initialisation and synchronising' I assumed this was an auto feature when the disks were first installed (by me) and the unit powered up. At this point I will give support a ring and see if they can help speed things along. Thanks again I will be in touch. paul
