Arthur_Dent
Nov 15, 2014Tutor
ReadyNAS NV+ power supply failure solution
Hi all, I recently had the all too common and dreaded power supply failure on my ReadyNAS NV+ (RND4000). The unit itself has worked flawlessly for the 5-6 years since purchase, until last week. I...
paulskpt
Aug 28, 2015Initiate
The power supply of my ReadyNAS RND4000 v3 (NV+) went down recently. With the quick and professional assistance of Overtek Ltd. (Overtek.co.uk) I today received a replacement power supply. I mounted it into the NAS, booted it up and everything worked flawlessly, 100%. Value 69 GBP + shipping.
Harleyfart
Oct 09, 2015Tutor
I acquired a power supply via Amazon from a vendor located in the UK, as well....solved problem, although the unit was not exactly the same as original. It was close enough in form and perfect in output. Minor mods required to make it work.
