tigerten
Jan 28, 2024Luminary
ReadyNAS OS 6.10.10 released
Link to download: https://www.netgear.com/support/product/readynas_os_6#download Release Note: https://kb.netgear.com/000065999/ReadyNAS-OS-6-Software-Version-6-10-10 Cleaned up a b...
Ken_Griffiths
Feb 22, 2024Star
I’m not sure it will downgrade StephenB as I did try that and it showed an error, but gave me back the option to install but Plex, but sadly that install just fails too. That said, I did not unzip the 6.10.9 installer to begin with, so I may give that another go as I later went back to installing 6.10.10.
Is it perhaps easier (less risky) to somehow copy the Plex.deb installer to the /apps/plexmediaserver directory and install it? … that’s all I’m hoping to achieve here. If I can get Plex up-to date I will just leave it there, as that’s all I use the NAS for anyway. I have the Plex.deb file in /data/Backup but didn’t want to try installing it from there.
Am I right in thinking too that the ssh command to install the Plex upgrade (having renamed the update installer file to ‘plexmediaserver’ is…
apt install ./plexmediaserver.deb
That’s once I can find the ssh command to copy it to the /apps/plexmediaserver directory.
… or will this not work, thanks to this Netgear OS 6.10.10 update?
I’m a bit ‘miffed’ that Netgear have done this. I did not personally receive any warning that this would happen. However I guess I have to accept it and move on.All I want to do is to get the Plex update to keep things going for as long as I can, until I can replace the NAS, which I realise I’m going to have to do at some point, but can’t really afford to at this moment in time.
Astra03
Feb 22, 2024Apprentice
"Am I right in thinking too that the ssh command to install the Plex upgrade (having renamed the update installer file to ‘plexmediaserver’ is…
apt install ./plexmediaserver.deb "
You said earlier in your post that the installation file is called Plex.deb ?
If that is the case then won't the installation command be:
apt install ./Plex.deb
