mobocracy
Apr 21, 2014Aspirant
SSD support for 2120?
I checked the compatibility list, but there doesn't seem to be any listed support for ANY SSDs in the 2120. Are they truly unsupported?
mobocracy
May 12, 2014Aspirant
No specific part number picked out. We have a client with an internal resource advocating a quick-fix to some performance-related storage issues. The internal resource was advocating a QNap box with SSDs. I've used these (I even own one personally) but I think the Netgear is a better (performance and focused) product. Neither vendor though supports SSD on their supported drives list.
As they say, "it's complicated" and the better solution for this client is stepping up with an upgrade to their existing Equallogic environment; they've put this off about two years longer than they should have, always balking at the price.
Nobody wants to move forward production-wise on an unsupported product mix. I've got my own suspicions about using desktop SSD in a SAN-type environment, especially in a smaller device without the slots to support N+2 hot spares due to limitations in write wear. I'm also skeptical that the payoff for an all-SSD device will be there without making the jump to 10 gig ethernet.
I'm not sure what Netgear or other storage vendors have got planned for SSD in future releases. It'd be nice to see mixed SSD and conventional platters in the same unit with a dedicating SSD landing zone for writes background migrated to platters and SSD cached reads of frequently accessed blocks, but this is a pretty sophisticated feature mix at this price point.
