dishmagic66
Jun 22, 2013Guide
Suggestion voor the OS6 addons
At this moment (OS 6.07) the layout of the addons is pretty anoying. Under the installed tab only really installed addons should be visible and not the addons wich are switched off and will be instal...
m1sterd
Jun 23, 2013Tutor
For the RN516 at least the 6.0.8 update has changed the Apps section quite a lot, I have put a brief description in this posting: viewtopic.php?f=10&t=71090&start=15
