DavidTuff
Mar 15, 2019Tutor
System Volume Root Usage is 82%
Logs says this:- "Volume: System volume root's usage is 82%. This condition should not occur under normal conditions. Contact technical support."
It started resyncing for some unknown reason. Been ...
- Mar 18, 2019
asimb wrote:
you are wrong: look at his screenshots again. The problem is in the /var/lib directory, not in the /lib.
Looking again, I agree. The second check was made in /var.
FWIW, AntiVirus is disabled on my RN526x. /var/lib/clamav holds
drwxr-xr-x 1 clamav clamav 102 Oct 29 23:20 . drwxr-xr-x 1 root root 298 Jan 27 06:16 .. -rw-r--r-- 1 root root 48 Oct 31 2017 antivir.ini -rw-r--r-- 1 root root 754688 Oct 31 2017 bytecode.cld -rw-r--r-- 1 root root 42530018 Oct 31 2017 daily.cvd -rw-r--r-- 1 root root 307499008 Oct 31 2017 main.cld -rw------- 1 root root 624 Apr 10 2018 mirrors.dat root@NAS:/var/lib/clamav#
So after it is turned off, it should be ok delete any subfolders (or other files) in /var/lib/clamav. I'd leave the five files above in the folder.
Mar 18, 2019Guru - Experienced User
asimb wrote:
Are you sure, that the directory doesn't exist? After you have logged on via SSH you have to type "cd /var/lib/clamav" to change to the directory. Then type "ls -la" to check what the directory includes.
Well, his big problem is clearly in /lib, not in /var. So I suggest that he repeat the du command in /lib - looking for the subfolder that holds the huge file(s).
DavidTuff - not sure why you attempted a balance. The root partition on your NAS uses the ext file system, not btrfs.
Also, if AntiVirus is running, then disable it from the web ui.
Your errors in du are happening because you ignored the guidance in my earlier link to remount the root partition as /mnt. However, in your case you can simply do a cd /lib and repeat the du. Identify the folder taking the 3 GB of space, navigate into it with cd and repeat the process.
Again, you are looking for a folder (ultimately a few files) that consumes 3 GB of space. Looking in frontview (which used only 30 MB) was a waste of time.
asimb
Mar 18, 2019Star
you are wrong: look at his screenshots again. The problem is in the /var/lib directory, not in the /lib. This is the same situation I had yesterday.
that's right: DavidTuff turn the AV off immediately
- StephenBMar 18, 2019Guru - Experienced User
- DavidTuffMar 18, 2019Tutor
All fixed, thanks for pointing me in the direction..
- Fabi8Mar 29, 2019Aspirant
Thank u for the information! :smileyvery-happy:
I did it ... and now it works again without warnings ! (in my case the System Volume Root Usage reached 98%)
