mopgcw
Sep 06, 2015Aspirant
ULTRASTAR HE8 8TB
FWIW, these have been running fine for two weeks now in a 716..model: HUH728080ALE600 / 0F23267
Sep 08, 2015Guru - Experienced User
mdgm wrote:
The guide is mentioned in our instructions as to be used with 3.5" drives. Qualifying a disk where this can't be used would confuse things.
Understood.
I think the bigger question is whether a 3.5" drive is safely mounted if you don't use the guide. I'm thinking it's provided for a reason.
jtclark
Nov 06, 2015Aspirant
I had already removed the middle "nub" from the guide for a prior drive model.
With that minor modification these drives fit using the guide.
Next time I power down I'll look a little closer.
- jtclarkNov 06, 2015Aspirant
I had trimmed the middle post out of the guide because the Seagate Drives I had been using did not have a screw hole for that "nub".
Having looked a little closer, the HUH728080ALE600 will fit into the tray with no modification to the guide.
