Esoteric
Aug 02, 2021Tutor
Upgrading my readynas
I've had my ReadyNAS for ages. I recently tried to swap out my drives to upgrade and it all failed. Luckily, there were some awesome people on here to help me out. After fixing everything I w...
Aug 02, 2021Guru - Experienced User
Esoteric wrote:
I formatted it to FAT32 using Disk Utility on my Mac.
That likely has something to do with it.
FAT32 has a file size limit (either 2 GB or 4 GB depending on the application). dmg files also can have "forks" (alternative data streams), and FAT32 can't handle them either.
If you don't actually need the files, you could delete them. Or maybe try zipping them - likely the zip file can be backed up.
Esoteric
Aug 03, 2021Tutor
StephenBthanks for the info. I may zip them.
Is there a better format so I can read and write from it using my Mac? That's why I originally chose FAT32.
- StephenBAug 03, 2021Guru - Experienced User
Not for native read+write. I generally recommend NTFS. You can read on the Mac by default, and there are a couple of options for enable writing. https://www.technology.org/2019/08/26/how-to-enable-ntfs-write-support-on-mac/
I don't own a Mac though, so I don't have any first hand experience with the NTFS options.
