gusman1103
Jan 29, 2021Aspirant
Reading files in my ReadyNAS using my android device
Hello, I am new to networking and I would like to know how to proceed with the set-up so I can view my files in my ReadyNAS Duo V2 using my Android device. I've used my Duo V2 for some years ...
Jan 29, 2021Guru - Experienced User
Solid Explorer should let you access the NAS - there is a (perhaps dated) guide here: https://www.guidingtech.com/smb-server-solid-explorer-android/
I can't give much advice, as I switched to an iPhone in December, and have no Android devices right.
Away from home is more tricky. The best way is to get a router that supports OpenVPN, and use that to access your home network when you are away. Orbi and Nighthawk routers both include openVPN.
