gusman1103
Jan 29, 2021Aspirant
Reading files in my ReadyNAS using my android device
Hello, I am new to networking and I would like to know how to proceed with the set-up so I can view my files in my ReadyNAS Duo V2 using my Android device. I've used my Duo V2 for some years ...
gusman1103
Thank you StephenB for your quick answer.
I am following the Solid Explorer guide and everything is fine until the end.... I see the IP of the NAS, I enter the user name and password to access it, but when I click connect I receive a message that there is a communication problem with the network. I enabled ReadyDLNA on the NAS, any other settings I should look into?
Sandshark
Jan 30, 2021Sensei
I use Total Commander with the LAN plug-in. While my NAS is an OS6 one, so supports SMB2 and SMB3, it appears to have settings that allow access to older devices.
