andersc
Sep 29, 2016Aspirant
ReadNAS NV+ will not power on.
ReadyNAS was shutdown to replace the UPS attached to it, but now it will not power on. Yes, I checked the power cable, etc. Is there any way to find out if my power supply is one of those with t...
DaneA
Sep 29, 2016NETGEAR Employee Retired
Hi andersc,
Welcome to the community! :)
Kindly access then read the old forum link below:
DaneA
NETGEAR Community Team
- anderscSep 29, 2016Aspirant
There is nothing in that old forum message that addresses a dead power supply.
- StephenBSep 29, 2016Guru - Experienced User
DaneA assumed the "known issue" you meant was the service action. Did you have a different "known issue" in mind? Let us know.
If your NAS serial number is in the range in the service action, then Netgear will give you a new supply even if the warranty has expired.
If not check for warranty coverage (5 years I think).
The PSU can be replaced. One option is to get a stock supply (SS-250SU for instance) and modify the pinout for the NV+. Here's a thread with a bit more information: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases/m-p/1016241#M13476
I was referring to the hundreds of other postings referring to the known issue with the power supplies dying prematurely.
I can not find a link to the serial number range, which would be very helpful.
