PMDev's avatar
PMDev
Ready nas 102 transfer speed
I have a Readynas 102, is seems to be a bit slow, it’s fitted with 2 4tb iron wolf drives and has a 1000mbps connection. I’ve ran a test with nas performance tester and the speeds are
Write 37MB / Sec
Read 21MB /Sec
    Write 37MB / Sec
    Read 21MB /Sec
    What firmware are you running?
    Is the PC connected using gigabit ethernet?
    • PMDev's avatar
      PMDev
      Latest FW, computer has gigabit connection
      • If the data volume is very old, doing a factory default will speed it up.
        Also, if ipv6 is enabled, then I suggest disabling it.
ProSupport for Business
