kitarou
Nov 14, 2022Aspirant
Ready NAS 104 backup failed
Ready NAS 104 backup to external HDD connected with USB cable failed. Message log says "Backup stopped due to read-only". The format of HDD is NTFS and recognized to 104 NAS. My setting is the follow...
kitarou
Nov 15, 2022Aspirant
How should I fix for this problem ?
- StephenBNov 15, 2022Guru - Experienced User
If the USB drive is in a format that Windows supports, then try ejecting the USB drive. Connect it to a Windows PC, and if it offers to "repair" it, then let it.
Not sure how this would be done on a Mac.
- kitarouNov 19, 2022Aspirant
Only the operation disconnecting external backup-drive from 104 main menu can not
disconnect normally. The access lamp of external back-drive HDCX-UTL(i-o data)
remains green, it is still connected.
The following is the fix procedure.
1) Connect external drive (USB HDD) to PC.
2) Disconnect external drive by normal PC operation.
---> recognizes disconnecting is normally.
3) Connect to external drive to NAS 104.
