onlyb2b
Jul 04, 2020Aspirant
ready nas 424 onedrive sync fail
I had successfully created online backup with onedrive.
but after 3 months, now I am not able to sync readynas with one drive.
following error occurred
credentials are correct and unchanged.
I think problem is ReadyNAS app is not able to authenticate with onedrive.
I am using one drive of office 365.
"Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with One Drive."
after removing all old sessions (backup jobs) it is working
- onlyb2bAspirant
Yes, I have the same problems, normally after the NAS is shutdown and restarts or there is a firmware upgrade. I have to reset the sync parameters for everythng which is time consuming and a little irritating. It's a shame because it works so well normally. Surely it should be possible to fix this?
- pietrobrTutor
Even after recreating the connection with OneDrive, there situation it fails to autenticate and you have to recreate the connection.
Please fix the resilience ot the app, OneDrive is important and essential as Cloud App.
Thanks in advance
