onlyb2b
Jul 04, 2020Aspirant
ready nas 424 onedrive sync fail
I had successfully created online backup with onedrive. but after 3 months, now I am not able to sync readynas with one drive. following error occurred credentials are correct and unchanged. I th...
- Jul 04, 2020
after removing all old sessions (backup jobs) it is working
Invicta21
Jun 21, 2022Tutor
Yes, I have the same problems, normally after the NAS is shutdown and restarts or there is a firmware upgrade. I have to reset the sync parameters for everythng which is time consuming and a little irritating. It's a shame because it works so well normally. Surely it should be possible to fix this?
