calaba
Apr 14, 2020Guide
Ready NAS 104 Crashes when changing Network setting (creating new bond) ...
I was following this thread describing my issue on RN 104 - any attempt of creating ethernet bond (even latest OS 6.10.3) leads to crash displaying something 'putname+14' on the display. The NAS hang...
Apr 14, 2020Guru - Experienced User
calaba wrote:
My SMB transfer spped to regular "1 snaphshot", "no bit rot protection" is horrible - on 300Mb WiFi to my NETGEAR WNDR4300v2 router directly connected with brand new Cat6 cables to RN 104 I am getting 10 - 14 MB/s transfer ... not even close to mentioned 70MB/s ... I even dream having the 35MB/s ....
FWIW, bonding won't help. The RN104 can't keep up with a single gigabit connection - so adding a second link won't help.
Are you measuring the speed over a wifi connection, or is the PC also connected with ethernet?
If you are using ethernet, have you checked that the PC and the NAS are running gigabit ethernet?
- calabaApr 15, 2020Guide
Did new test,
PC file transfer via:
1) WiFi 300 Mbps -> guessing WiFi is half-duplex -> so 300 / 2 / 8 gives me teoretical speed up to 18,75 MBps - I was hitting around 14MBps so that was pretty close to maximum I guess.
2) Gigabit Ethernet (yes I checked it is detected on router and NAS as 1GB and not 10/100Mbs) -> then I was getting around 30MBps using wired transfer. It is still not the max reported (70MBs) but because of the crash while setting the ethernet bond NAS is now re-syncing several TBs so it will take a couple of days before I can run 2nd test via wired connection.
- StephenBApr 15, 2020Guru - Experienced User
It's not half duplex. It's true that only one device (including the router) can send or receive at a time. But if you are only downloading (and no other devices are using the WiFi), you can use the full link in the download direction. Likewise for uploading.
But real-world throughput is always a lot less than the link speed. ~100 megabits is reasonable for a 2.4 ghz wifi connection.
Test it again after the sync is finished. If your volume is very old (especially if you started with 6.1.x firmware), you might consider doing a factory reset and rebuilding the NAS (restoring data from backup). You will see a speed increase if you do that.
Hi, well I do have the NAS few years but had some factory reset 3 years ago - do not remember what was the version at that time. Doing factory reset will require backing up my 5TB somewhere, will take a while. Is there any chance that OS reinstall without destroying the data volume would help with increased speed ?? Or the only way is to get newest OS + fresh new volume and restore the 5TB from some backup ... ?
