Dremscape
Jan 18, 2019Aspirant
Ready NAS 104 Crashes when changing Network settings putname+14, kfree+168
Seem to be having trouble changing my network settings, currently have 2 Nics teamed and set to use Transmit Load Balancing (Layer 2), initially I was trying to just change the MTU size, but when I d...
- Jan 17, 2020
jgisin wrote:
I have this same issue. I'm trying to delete the bond0 so I can create a new one and I get kfree+168 on the LCD. Same thing if I just try to modify the bond. WTF? How about some reliefe from this nonsense?
I am running the latest 6.10.2
Hopefully it's on the list of things to be fixed.
One thing you could try is doing an OS reinstall from the boot menu. That will
- reset the network to default settings (no bonding, MTU=1500, dhcp)
- change the admin password back to password
- disable volume quota (can be changed back on the volume settings wheel)
See pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
FWIW, the RN100 series performance is mostly limited by it's relatively slow processor and memory. There's not a lot of performance gain to be had with bonding. I'd just use it with one ethernet connection myself.
Jan 19, 2019Guru - Experienced User
Dremscape wrote:
None of the changes take effect after restarting. Current OS version was 6.9.4 (Hotfix 1), have since tried upgrading to latest beta to see if this resolved the issue, It did not.
6.9.5 has been released for about a week now - so if you are running beta or release candidate you should update it.
If you are running the 6.10 beta, then stay with it - you aren't able to downgrade back to 6.9.x.
Dremscape wrote:
Following this I decided to delete the bond entirely, same thing happened
Perhaps also try removing one of the ethernet cables.
If you are on the 6.9.x branch, maybe also try 6.9.3 and see if that changes the behavior.
