Dremscape
Jan 18, 2019Aspirant
Ready NAS 104 Crashes when changing Network settings putname+14, kfree+168
Seem to be having trouble changing my network settings, currently have 2 Nics teamed and set to use Transmit Load Balancing (Layer 2), initially I was trying to just change the MTU size, but when I d...
- Jan 17, 2020
jgisin wrote:
I have this same issue. I'm trying to delete the bond0 so I can create a new one and I get kfree+168 on the LCD. Same thing if I just try to modify the bond. WTF? How about some reliefe from this nonsense?
I am running the latest 6.10.2
Hopefully it's on the list of things to be fixed.
One thing you could try is doing an OS reinstall from the boot menu. That will
- reset the network to default settings (no bonding, MTU=1500, dhcp)
- change the admin password back to password
- disable volume quota (can be changed back on the volume settings wheel)
See pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
FWIW, the RN100 series performance is mostly limited by it's relatively slow processor and memory. There's not a lot of performance gain to be had with bonding. I'd just use it with one ethernet connection myself.
Trickydicky666
Jan 24, 2019Aspirant
I have exactly the same issue, i am trying to Bond Eth0 and Eth1 and everytime i make the link it locks up solid and gives me the kfree+168, i had this on 6.9.4 and now on 6.9.5 exactly the same. I have 4*4gb drives raid 10.
- DremscapeMay 15, 2019Aspirant
Have now updated to latest stable build 6.10.0, yet the issue still remains, any attemt to change the NIC settings to anything else results in it locking up and erroring.
- JohnCM_SMay 17, 2019NETGEAR Employee Retired
Hi Dremscape,
Can you download the system logs then provide it to us? We will further what is causing the error.
You may upload it to Google Drive then send to me the download link via PM (private message).
- Trickydicky666May 18, 2019AspirantI managed to sort the issue, bought a Synology ds1819+ have bonded 4 Ethernet and it’s 10x faster. Ready NAS 104 for sale now! 😀
