mapochatka
Sep 13, 2024Follower
Ready NAS 2304 Antivirus definition failed to upload. Check internet connection
Firmware 6.9.6
I even rebuilt my readynas box from the scratch to get this to work - and i have tried solutions from other posts
1 Reply
mapochatka wrote:
Firmware 6.9.6
Which is the problem.. You need at least 6.10.8 (there are several fixes for ClamAV in various 6.10.x releases).
If you have installed apps via the admin web ui, then I recommend upgrading to 6.10.9.
If you haven't installed such apps, then I recommend upgrading to the current firmware (6.10.10).
