thompssp
Feb 18, 2019Tutor
Ready NAS 422 Folder Syncing from alternate drives
I am looking into purchasing a NAS box for my home (I already have the WD Red 4TB drives) and I am very interested in the Netgear Ready NAS 422 enclosure (I'm not sure if the model # I put above is c...
Feb 19, 2019Guru - Experienced User
thompssp wrote:
Are there other apps you can use with this enclosure other than Ready Cloud that could accomplish this?
You can sync with Resilio sync. There are also several cloud options (which would let you sync the PC folders and the NAS to cloud storage).
Personally I back up my PCs to the ReadyNAS when I am home - avoiding the need to use ReadyCloud for that.
thompssp
Feb 19, 2019Tutor
Thanks for the reply StephenB. I really appreciate the feedback.
