tlunak
Jun 03, 2024Aspirant
Ready NAS Duo - RND2000-100NAS cannot access Frontline
I have an old Ready NAS Duo that cannot access Frontpage. Here is a screenshot from Raidar: When I try the Admin page I get the following: I am thinking of buying a new NAS but I...
Jun 04, 2024Guru - Experienced User
tlunak wrote:
I'm having an issue with the music library and SONOS (library resides on the NAS) and I need to get some information from the NAS.
What information are you looking for?
FWIW, Netgear has exited the NAS business, so you'd need to go with another vendor.
How long as it been this way?
tlunak
Jun 04, 2024Aspirant
Length of time it's been like this is heard to estimate. I use the NAS only for music storage and have never had much need to access Frontpage.
- saudadeJun 04, 2024Apprentice
What browser are you using? Did you get any error message accessing the admin page but were allowed to continue?
- tlunakJun 04, 2024Aspirant
Using Safari and also tried Chrome. There was no error message received. That blank Frontpage screen loaded and then it stopped. None of the icon links worked.
- StephenBJun 04, 2024Guru - Experienced User
A couple of things
- You are running old firmware from 2012, not the final firmware (4.1.16).
- Most new browsers (including Chrome and Safari) should be giving you an error. Both require TLS 1.2, and your NAS only supports TLS 1.0
The second change was made over two years ago (early 2022).
Your screenshot is puzzling - can you try browsing to http://192.168.1.34/admin and see if you get the same result? The /admin bit matters - don't leave it out.
What information are you needing to get from the NAS????
