andy_f
Oct 31, 2015Aspirant
RND2000-100NAS fail
After several years my RND2000-100NAS appears to have failed. Yesterday I could not access it and found it was completely dark, no lights. It would not power up. I verified AC power was good and verified 12 V at the output of the power supply brick. I disconnected all cables going to the ReadyNAS (power supply, ethernet, USB cable to battery backup), then reconnected everything except the USB cable. ReadyNAS now powers up and the indicator lights look normal but I cannot access the drive. I verified the ethernet cable connected to the ReadyNAS is good but the ReadyNAS is not visible on the network. RAIDar scan does not find it either.
Is there any further troubleshooting I can do?
If not, how do I recover the data from the two 1TB drives? The RND2000-100NAS I have is version 1.
Thanks!
Andy
if you are using xraid, you can get the data off using linux reader-connecting the data drive to a windows PC (http://www.diskinternals.com/linux-reader/)
Usually the data disk is in slot 1 (leftmost) and the parity disk is in disk 2. So try disk 1 first. If you don't see the data volume, then try disk 2.
- andy_fAspirant
Thank you very much Stephen! I installed the software you recommended, removed the drive from slot 1 of the ReadyNAS, put it in an external drive enclosure, and was able to recover almost all of my files. My backup files are unrecoverable for some reason but it appears I was able to recover all other files.
Your advice was a lifesaver, thank you very much. Based on this experience I will no longer store irreplaceable data on a ReadyNAS. The redundancy of RAID protects against hard drive failure but I hadn't considered that failure of the ReadyNAS unit itself would result in a situation where I am dependent on 3rd party freeware that may or may not be able to recover my data.
Thanks much for the help Stephen!
- mdgm-ntgrNETGEAR Employee Retired
You shouldn't store irreplaceable data on any single device, no matter what that device is.
Backups are vital.
