WellingtonBDS
Mar 06, 2023Aspirant
Ready NAS duo V2 does not access frontview
Hello!
I have a ReadyNAS Duo V2 and I haven't entered the setup for a long time.
The system is Windows 10 and the problem happens in all browsers
It is working and I have access to the files.
Now I need to enter the setup and I can't because the browsers don't accept the communication protocol.
NASnumberIP/admin
An error occurred during a connection to 192.168.1.208. The remote system uses an unsupported version of the security protocol.
Error code: SSL_ERROR_UNSUPPORTED_VERSION
This site may not support the TLS 1.2 protocol, the minimum version supported by Firefox.
Only the IP number
NASnumberIP/shares
incomplete sharing, only access to password change
Maybe updating the firmware will do it, but I can't install it without accessing the setup
WellingtonBDS wrote:I have a ReadyNAS Duo V2
Your screenshot appears to be from the original Duo (called a v1 here).
The original Duo (v1)
- runs 4.1.x firmware
- says "ReadyNAS Duo" on the front panel.
The Duo v2
- runs 5.3.x firmware
- says "ReadyNAS Duo v2" on the front panel.
Ignore other labels, they are more confusing than helpful.
This site may not support the TLS 1.2 protocol, the minimum version supported by Firefox.See this thread:
If you skip to the end, you'll find a setting which allows FireFox to connect. One downside of doing that is that it enable TLS 1.0 generally (for all websites). If you run Windows, then Internet Explorer or Edge in IE mode will also work.
Editing virtual.conf (once you regain temporary access) is another option, instructions for that in the beginning of the thread.
The Duo v2 add-on won't work in your case (since you actually have a v1).
Only the IP number
NASnumberIP/shares
incomplete sharing, only access to password changeThat only shows you something if you have configured one or more shares to allow HTTP access.
- WellingtonBDSAspirant
Thank you for the informations
I read your post (2022-03-05 03:50 AM) detailing the procedure, I copied the script in notepad++ and saved it in a shared folder on the NAS, I downloaded SSL EnableRootSSH_1.0.bin, but I don't know how to use it to access the root from the NAS- WellingtonBDSAspirant
I installed FireFox 94.0.2 and now access the NAS frontview
Hostname: nas-6B-AC-B6
Model: ReadyNAS Duo [X-RAID]
Serial: 24M4147V00C80
Firmware: RAIDiator 4.1.16 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.1.208
Volume C: Online, X-RAID, 2 disks, 79% of 1846 GB used
