Dave_Waine
Dec 22, 2014Aspirant
Ready NAS network errors
I have a Ready NAS Pro 6. The interface is set for Adaptive load balancing. If either one of the interfaces is connected then all is ok (but it is only a single, non redundant connection). As soon a...
Jan 08, 2015Guru - Experienced User
Not to me. The RN104 doesn't have the horsepower to generate more than 1 gbit of traffic. So no matter how the teaming plays out, you won't overrun the interface.
Dave Waine wrote: I have a ReadyNAS104 set to ALB connected to the same switch - all seems fine with no errors.
Implies that the ReadyNAS 6 is faulty.
It is interesting that the errors are on the RX, and not TX. The load balancing choice only affects TX traffic. What is generating the traffic load? Are you using multiple clients simultaneously? Or a client that also uses teaming? Are you seeing errors on both NICs?
