NAS-SAN-NAS
Sep 12, 2016Aspirant
Ready NAS not shutting down or rebooting - RN316
Hello folks in the community, I cannot shut down my ReadyNAS gracefully. Over the GUI it hangs on shutdown - the display is showing " Powering Off - Goodbye" I also tried the hardware button met...
JennC
Sep 13, 2016NETGEAR Employee Retired
Hello NAS-SAN-NAS,
When you try to update the firmware, what exactly happens? Also, when you change some settings, does it take effect?
Also, what are the apps installed and running? It is possible that there are some activities running in the background.
I also strongly recommend to (always) backup the files.
