JOJO1
Sep 21, 2015Aspirant
Ready NAS NV+ - Different disk size
Hi I have an ReadyNAS NV+ and faulting disk and have to by a new one. Is it possible to increase size only on one disk. Today its 4 * 1TB drives and i want to change one drive to 2TB (for the ...
- Sep 21, 2015
It will accept the drive but you won't get any expansion replacing just the one disk.
If it is the v1 then you would need to replace all four disks (one at a time of course) to get expansion.
If it is the v2 then only two disks would need to be replaced to get expansion.
Note that 2TB disks are the max capacity supported by the v1.
mdgm-ntgr
Sep 21, 2015NETGEAR Employee Retired
JOJO1
Thank You for reply.
It´s a V3 version of NV+
I´m going to order a 2TB (or two).
regards
Johan
