HIT-247
Jun 24, 2017Aspirant
Ready NAS RND 2000 How long install ? Flashing Blue Lights ben on for an hour ?
OK just carried out factory reset and used RAIDar to start installation. I am only using 2 x 1TB drives as a test exercise and it is taking a long time with flashing blue light mode ? No response...
Hopchen
Jun 24, 2017Prodigy
Hi,
A Factory deafult shouldn't take more than a few minutes really. So, something is up.
You sure that your disks are OK? Could easily be faulty disks causing this behaviour.
HIT-247
Hi
Yeah I had a problem with one of the drives. I took it out and tested the reset with one drive and it seems ok.
However admin and password do not work ?
Help ?
- bedlam1Jun 24, 2017Prodigy
The Factory Default has reset your password to the default password which is password
- HIT-247Jun 24, 2017Aspirant
Yes that is what i thought. I have just added a 2nd drive and gone through the reset process again. So once it has finished creating the volume I will try admin and password again ? Fingers crossed it works this time ! ANy other ideas let me know ?
- HopchenJun 24, 2017Prodigy
The default admin password for these older units is not: password
Instead it is: netgear1
