amcell
Aug 17, 2017Aspirant
ready nas ultra 6 Drive expansion with 6tb drives
Hi, Can someone tell me if I can install 4 x 6tb drives to my Readynas ultra 6 (Clean install) Would I get the full 18tb(3 x 6tb) with 6tb(1 x 6tb drive) acting as raidx redundancy shoudl i stic...
- Aug 17, 2017
You can, and you will get the 18 TB volume. XRAID expansion will fail, so you should use FlexRAID. That will let you add additional disks (as another volume) later on.
amcell wrote:
As an alternative to above Is it possible to add a second raid volume using 3 x 6tb to get 12tb with 1 drive being redundant and can i co-exist with the original volume
You can do that with flexraid, but not the default xraid. And switching to flexraid would require a factory reset.
The net here - a factory reset (or install) is in your future. You should consider switching to OS 6 as part of the upgrade. It will give you more expansion options later on.
Aug 17, 2017Guru - Experienced User
