UltraGar
Jul 16, 2019Aspirant
Ready NAS Ultra 6 Plus - OS 6.9.5 >> 6.10 Upgrade Fail - Safe Mode Options
Hello,
I realize this is a legacy device, and that OS 6 is not officially supported, but I hope someone here can help.
I previously updated my legacy Ready NAS Ultra 6 Plus (6x 3TB drives) from OS 4.2.XX to OS 6.9.5 without any problems. Tonight I was prompted to upgrade the OS to 6.10, without performing a backup (my bad), and after reboot, the NAS:
1. Passes the Root FS check;
2. Boots in increments going to 99% and stops;
3. Enters into 6.9.5 safe mode.
RAIDar 6.5.0 detects the NAS and shows:
1. Name: readnasos
2. Firmware: 6.9.5
3. Status: Volume data RAID Level 5, Inactive, 100% of the volume used
4. All Drives show a green checkmark.
5. Offline Setup (LAN) is the only option. No option to Download Logs or perform Diagnostics.
Logging into the Admin interface, the message is "ReadyNAS failed to boot successfully" and provides several options include formatting the Volumes, OS Reinstall, and Boot into Read-Only mode.
I want to avoid formatting the Volume for obvious reasons.
I've performed OS Reinstall several times with no success. I moved all 6 drives to another Ultra 6 Plus unit (running 6.9.5) and the same problem occurred. Tried to use NAS #2 to OS Reinstall with no success. Moved the drives back to NAS #1, where the problem persists.
I want to boot into Read Only mode and access the data, but the Boot Menu on this Legacy NAS does not provide the option, at least as a top-level option.
I also attempted a USB Recovery using the 6.9.5 x86 firmware, using 3 different USB sticks, but could not get the NAS to enter USB Recovery mode.
I hope someone else has run into the same problem as I have and can offer some suggestions.
Thanks!
Do you have experience with linux commands? There are some things you could try in tech support mode.
ReclaiMe RAID recovery software is another option, though it is expensive (and requires a way to connect all your disks to a PC).
- UltraGarAspirant
I don't have a lot of experience with Linux, but am willing to try. Would I be doing steps similar to this to try mounting the volume in Read Only mode?
You could try that, and if those commands work do a backup of the NAS.
You'd boot in tech-support mode, and telnet into the NAS. User/pass is root/infr8ntdebug
Then enter
# rnutil chroot
Which will start RAID and chroot.
It might be worth trying to re-apply the firmware update next. You'd do this by
# touch /.os_update
# rebootIf that fails, you'd have to reboot in tech support mode, and go in again.
