Niyaj
Aug 17, 2018Follower
Readydata 5200
can u help.. i have Netgear readydata storage 5200. that storage ip is auto changed. now i find ip but can't access my previous datas. i change default ip to my old ip that time error is "settings are not changing first you create volume" how i solve that error without delete my datas..
1 Reply
- Marc_VNETGEAR Employee Retired
Hi Niyaj
Welcome to the Community!
Have you done any procedure before this happened? It seems that your ReadyData volume was lost/deleted. Settings will not be saved unless there is a volume created, Are your disks still showing?
I would suggest contacting NETGEAR Support so they can properly assist you with your ReadyDATA. Please note that there might be Data Recovery service which will have a fee.
Regards
