HUMMER1987
Jan 31, 2019Aspirant
ReadyDR Setup HELP!!
Hi I have been using Replicate for years and proably becuase its very straight forward havent had any major issues with it.
I am trying to setup ReadyDR and I cant seem to move past a point an...
- Feb 12, 2019
Hi HUMMER1987
Have you tried recreating the ReadyDR job? You will most likely to redo the exchange key and use Manual procedure. Also, instead of using the DNS can you use IP address?
Please see
We tried to replicate it on our units and seems to be working fine. I will try to check further if needed.
Hope this helps!
Regards
