Retired_Member
Sep 24, 2014ReadyNAS 102 - external USB network LAN card
Hello, I would like to connect external LAN card for my ReadyNAS 102. I have a USB-LAN (HAMA Model name:00049244) but when I connect I can't set it's IP address. This card works in Debian without a...
mdgm-ntgr
Sep 24, 2014NETGEAR Employee Retired
We use connman in OS6
We probably don't have the necessary drivers for this either. So you may need to compile those.
This isn't supported and the internal LAN ports would give better performance.
