Retired_Member
Sep 24, 2014ReadyNAS 102 - external USB network LAN card
Hello, I would like to connect external LAN card for my ReadyNAS 102. I have a USB-LAN (HAMA Model name:00049244) but when I connect I can't set it's IP address. This card works in Debian without a...
Retired_Member
Sep 24, 2014Thanks! Good.
I can see IP settings for internal ETH is OK. "ethernet_28c68...." but I can't see my USB_LAN card in /var/lib/conman/
When I connect USB_LAN to NAS and reboot I should see a directory od second card? If not it means that I have no drivers installed. Am I right?
I can't find linux drivers for (HAMA) USB_LAN (only Windows and MAC), could you recomend USB_LAN device for ReadyNAS?
Is there the list of compatibile USB devices?
