Retired_Member
Sep 24, 2014ReadyNAS 102 - external USB network LAN card
Hello, I would like to connect external LAN card for my ReadyNAS 102. I have a USB-LAN (HAMA Model name:00049244) but when I connect I can't set it's IP address. This card works in Debian without a...
mdgm-ntgr
Oct 08, 2014NETGEAR Employee Retired
Well then, I think you got the wrong model for your requirements.
Even if you can find a way to make this work, performance will be poor.
I would recommend getting a 312.
