jwgmorley
May 23, 2017Aspirant
ReadyNAS 102 - Sharing Folders
Hello & apologies if this is in the wrong section. I've have a folder I would like to share with a flatmate however I'm having issues carrying this out. I've logged in as admin, created a new fol...
- Jun 09, 2017
I've kinda sorted it.
On one part I think I was being silly trying to untick the DNLA option within the section that gives you 4 choices. All I needed to do was move the slider to off within the DNLA section which sorted this particular issues.
With regards to sharing folders. Because of what the DNLA issue threw up I've now made a folder I wish to share with DNLA protocol and put a shortcut of said folder onto the persons desktop. Seeing as they will be scanning docs which aren't really sensitive and just need to be saved then it doesn't matter if anyone can view these.
I've had my 102 for nearly 5 years now and I can't fault it however the folder sharing issue seems bizarre. I'm just glad that this isn't something that's critical to me.
Sandshark
May 29, 2017Sensei
It sounds like you created a local user for him and then separately had him create a ReadyCloud user. That's two different users and one cannot have access to the personal folder of another. This is one of the things about ReadyCloud I believe is seriously flawed, but you need to work around it or live with it.
Does he need remote access? If not, forget about ReadyCloud and just have him access the NAS locally using the local account you created. If he does, he can use ReadyCloud all the time once you have given access to him vioa ReadyCloud and use his ReadyCloud account home folder or you can create a special folder that is not a home folder and give both users access to that folder.
