jwgmorley
May 23, 2017Aspirant
ReadyNAS 102 - Sharing Folders
Hello & apologies if this is in the wrong section. I've have a folder I would like to share with a flatmate however I'm having issues carrying this out. I've logged in as admin, created a new fol...
- Jun 09, 2017
I've kinda sorted it.
On one part I think I was being silly trying to untick the DNLA option within the section that gives you 4 choices. All I needed to do was move the slider to off within the DNLA section which sorted this particular issues.
With regards to sharing folders. Because of what the DNLA issue threw up I've now made a folder I wish to share with DNLA protocol and put a shortcut of said folder onto the persons desktop. Seeing as they will be scanning docs which aren't really sensitive and just need to be saved then it doesn't matter if anyone can view these.
I've had my 102 for nearly 5 years now and I can't fault it however the folder sharing issue seems bizarre. I'm just glad that this isn't something that's critical to me.
Sandshark
Jun 07, 2017Sensei - Experienced User
Many Windows users do not realize that a Linux (and thus ReadyNAS) user name and password are both case sensitive. The error you are getting without being asked for another password is probably because you told Windows to remember the (wrong) credentials and you need to clean them out of the credentials manager. In the search box, type "cred" and you'll see it availablle. Just delete any credentials assoiated with the NAS, then log out of Windows and back in.
jwgmorley
Jun 07, 2017Aspirant
There are no saved credentails in either web or windows credentials. It's a brand new laptop (yesterday) and other than 2 pieces of software nothing has been installed.
