jwgmorley
May 23, 2017Aspirant
ReadyNAS 102 - Sharing Folders
Hello & apologies if this is in the wrong section. I've have a folder I would like to share with a flatmate however I'm having issues carrying this out. I've logged in as admin, created a new fol...
- Jun 09, 2017
I've kinda sorted it.
On one part I think I was being silly trying to untick the DNLA option within the section that gives you 4 choices. All I needed to do was move the slider to off within the DNLA section which sorted this particular issues.
With regards to sharing folders. Because of what the DNLA issue threw up I've now made a folder I wish to share with DNLA protocol and put a shortcut of said folder onto the persons desktop. Seeing as they will be scanning docs which aren't really sensitive and just need to be saved then it doesn't matter if anyone can view these.
I've had my 102 for nearly 5 years now and I can't fault it however the folder sharing issue seems bizarre. I'm just glad that this isn't something that's critical to me.
Jun 07, 2017Guru - Experienced User
Since you use admin credentials when you log into the admin web page, you should be able to access everything.
So I am confused on what is wrong.
jwgmorley
Jun 07, 2017Aspirant
Hi StephenB, I'm not logging into the admin webpage on the new laptop. One of the issues is that anyone with my wifi password seems to be able to select File Explorer - This PC & gain access to my NAS this way without being asked for any credentials.
My comment re logging into the admin portal was simply to point out that I could see the shares and the access priorities and could change them yet it wasn't having any impact to files marked everyone. Plus there were admin only files that were accessible as mentioned above without the need for credentials yet others weren't viewable.
