ukbobboy01
Nov 02, 2023Apprentice
ReadyNAS 102 / OS6.2.5
Dear Forum Members I have just purchased from Ebay (UK) a ReadyNAS 106 running firmware 6.0.8 but, as most of you can guess, it is no longer possible to upgrade the firmware online, the only down...
- Nov 02, 2023
A simple Google of ReadyNAS 6.2.5 takes you here: ReadyNAS-OS-Version-6-2-5-RN102-RN104-Only
Sandshark
Nov 03, 2023Sensei
Since many things have changed since 6.5.2, you really should update to the latest OS version before you "get to know it".
Yes, the forum's internal search engine is pathetic. Google is far better for finding anything in the forum. If you have question, use Google to see if you can find an answer here. But if not, post it (in a new thread, please).
Nov 03, 2023Guru - Experienced User
Add site:kb.netgear.com to the search string if you want to search the Netgear knowledge base, and site:community.netgear.com if you want search the forum.
