Pierre57
Jul 20, 2016Aspirant
ReadyNAS 102 6.5.1 Upgrade Issues
My set up is a ReadyNAS 102 using a powered Seagate 2TB SRD00F2 USB drive for backup. Firmware was 6.4.2. This had worked flawlessly for many months, maybe a year. The ReadyNAS is less than 40% used ...
BrianL2
Jul 20, 2016NETGEAR Employee Retired
Hi Pierre57,
Welcome to the community!
Here are the answers to your questions.
- Is firmware 6.5.1 appropriate for a low end unit like the 102? Yes, there shouldn't be any problem with 100 series running the latest 6.5.1 firmware.
- Should I be concerned about the error? I'm not quite certain about this error message but I could pass this along to my colleagues.
- Shouldn't the eSATA drive be recognised automatically? What was the file format of the hard drive?
Kind regards,
BrianL
NETGEAR Community Team
- Pierre57Jul 21, 2016Aspirant
Thanks for the reply BrianL.
It would be useful to know what the error is, and how it could be fixed thanks.
The eSATA drives have all been NTFS 2.5inch drives. The lack of any "whirring" makes me think the drives aren't spinning up so I am thinking it may be a power issue. Does the ReadyNAS provide power through the eSATA PORT?
Pierre
- StephenBJul 22, 2016Guru - Experienced User
No. There is a variant of eSATA called eSATAp that includes power. But normal eSATA doesn't provide power, and that is what the NAS uses.
- Pierre57Jul 22, 2016Aspirant
Ok, thanks StephenB.
Any further thoughts on the error message?
As backups seem to be robust again, I am thinking of resetting the drive and restoring from the backups. I am not sure I trust the ReadyNAS when it is showing an error, but based on the time it took to reinstate the backups, a restore will take ages.
Pierre
