geoldr
Dec 02, 2014Tutor
ReadyNAS 102 8TB Max
Hi guys I have a question about the max size for my new NAS. I see on the tech spec that it is listed to support up to 8TB Max. I can only put in 2x4TB drives? I see there are 6TB drives on the mar...
Dec 02, 2014Guru - Experienced User
The notes on the three hitachi drives are actually mistakes- carryovers from the pro/ultra lists.
AFAIK the 6 TB drives work on the RN100 series now, as long as you stay below the 16 TiB total volume size. If so, Netgear doesn't need a firmware release to support them.
In the case of the RN102, its impossible to exceed the 16 TiB volume size anyway. But as lxa/vandermere are saying, you will lose support if you use them. Seems a bit silly to me.
