geoldr
Dec 02, 2014Tutor
ReadyNAS 102 8TB Max
Hi guys I have a question about the max size for my new NAS. I see on the tech spec that it is listed to support up to 8TB Max. I can only put in 2x4TB drives? I see there are 6TB drives on the mar...
Dec 02, 2014Guru - Experienced User
Well, do keep in mind the implications of no support. When you do get to the point where you need the space, research it here before you purchase the drives.
I haven't tried them myself, but my understanding is that they will work as long as the total volume size is 16 TiB or less.
