geoldr
Dec 02, 2014Tutor
ReadyNAS 102 8TB Max
Hi guys I have a question about the max size for my new NAS. I see on the tech spec that it is listed to support up to 8TB Max. I can only put in 2x4TB drives? I see there are 6TB drives on the mar...
Dec 02, 2014Guru - Experienced User
Costing out your options is always a good idea. Replacing working drives with new larger ones sometimes isn't the cheapest path.
vandermerwe wrote: I would also figure out the financial cost of upgrading to 6 tb drives versus selling the 102 and getting a 104 and sticking with the 4 tb drives you have, adding as you need more space.
Here in the uk, a 104 is much cheaper than a 6 tb drive.
Though he doesn't need the space now, so I think this all a "what if" for the future. Prices will undoubtedly change.
