geoldr
Dec 02, 2014Tutor
ReadyNAS 102 8TB Max
Hi guys I have a question about the max size for my new NAS. I see on the tech spec that it is listed to support up to 8TB Max. I can only put in 2x4TB drives? I see there are 6TB drives on the mar...
Dec 02, 2014Guru - Experienced User
Well, when the time comes you could potentially buy another RN102 and two more 4 TB disks - and split your storage across two devices.
So there are lots of options.
