karimtls
Apr 29, 2020Aspirant
ReadyNAS 102 not showing on my network and the disks leds are not on
i have four ReadyNAS 102 on my network. Two of them suddenly disappeared from the network completely when I look at the devices i can see the Act LED on But the Disks 1 and 2 LEDS are off. I cant ...
- Apr 29, 2020
Corrupted flash, which might be cured by a USB recovery, is still a possibility. But that it happened on two units doesn't point me to that straight off. Do you know if both actually went off-air at the same time, or were they just noticed within a small timeframe?
Did anything odd, like a power surge or local lightning strike, occur in the facility? Are the NAS protected by UPS? Do any share the same UPS?
Sandshark
Apr 29, 2020Sensei
Step one is usually to remove the drives with power off and re-boot without them. Label the drives so you know which slot they go it.
If RAIDar then finds the NAS with a "No Disks" status, then the hardware is fine and the issue is with the drives, probably something in the OS partition, but possibly actual bad drives.. Assuming RAID1, you can also try booting with just one drive at a time.
karimtls
I tried that but it still noy showing anything
