SGsydney's avatar
SGsydney
ReadyNAS 102 not working
Hi there,
My nas102 stopped working on my laptop since I updated to new firmware 6.7.5. on the laptop, it shows offline and doesn't connect. but I can access admin page and can access NAS through my iPad or mobile but not through my laptop. I have tried uninstalling and installing the ready cloud but to no avail. I am using Windows 10.
Help, please.
Thanks
  • StephenB's avatar
    It only fails with Readycloud?  You can access the NAS locally with file manager (entering \\nas-ip-address into the address bar)?  Use the real ip address of course.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello SGsydney,
    If you are referring to accessing the ReadyNAS through ReadyCloud desktop client, we had a problem with it that it would get a "VPN Disconnected" error message few days ago but it should be resolved now. Please try rebooting the computer and make sure that there is no firewall security software that may be blocking it.
    Locally accessing the NAS can be done as well without using the ReadyCloud, it is just by typing \\<IP address of the NAS> (ex. \\192.168.3.15).
    Welcome to the community!
    • SGsydney's avatar
      SGsydney
      Hi,
      Still, I can't access nas through ready cloud app on laptop. I have tried on 2 different computers but still same issue. I get error message as system offline on both computers.
      When I tried through admin page, under cloud settings, ready cloud shows off. And when I tried to switch on the cloud with username and password, I get the following error message " something is preventing the ready cloud to go online. Please reboot your nas". When I do that I get the same message.
      Thanks,
      • JennC's avatar
        JennC
        Hello SGsydney,
        Please make sure UPnP is enabled on the admin page's Settings > Services.
  • JennC's avatar
    JennC
    Hello SGsydney,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
